Old 07-19-2011, 09:06 PM   #35 (permalink)
orbywan
Moller improved the Volkswagen 'brick' from Cd 0.76,to Cd 0.42 with front radii.
Walter Lay,in 1933,built a full-size brick on a GM truck chassis.Leading edge radii cut drag from Cd 0.88,to Cd 0.42.
In 1963,GM investigated 18-wheeler drag.A fully radiused front was just a smidgeon ( sp?) better than an 18-inch radius.
In 1936,Fachsenfeld modified an Omnibus bus,with an inflatable boat tail which brought the drag own to Cd 0.158.His tail is the best I've seen so far.It's in Hucho's book.
The NUNA-3 team boat -tailed 'everything' on the car and achieved Cd 0.077.
The back really is where the pot-of-gold it hiding.
OK, I’ll play with the air dam when the belly pan is finished, thanks for the information Phil, and everyone else for weighing in on this, the comments and advice are very appreciated. I know enough to be dangerous at this point. I just spent the last few days before and after work building the front part of the A/C fairing, photos are below.
It was probably more trouble than it was worth but I wanted to add a rear looking roof cam to my system and this way I was able to incorporate that into the fairing. It’s kind of long but I still have room for solar panels. Probably would have been easier to just take it off and relocate it but it’s done for now.
Name:	Aero RV 38.jpg
ID:	9027   Click image for larger version
Name:	Aero RV 39.jpg
ID:	9028   Click image for larger version
Name:	Aero RV 40.jpg
ID:	9029   Click image for larger version
Name:	Aero RV 41.jpg
ID:	9030   Click image for larger version
Name:	Aero RV 42.jpg
Name:	Aero RV 43.jpg
ID:	9032   Click image for larger version
Name:	Aero RV 44.jpg
ID:	9033   Click image for larger version
Name:	Aero RV 45.jpg
ID:	9034   Click image for larger version
Name:	Aero RV 46.jpg
ID:	9035   Click image for larger version
Name:	Aero RV 47.jpg
The Following User Says Thank You to orbywan For This Useful Post:
HHOTDI (01-12-2013)
