NIce numbers! And, it's only "work" until it's second nature.
Trip planning plays a big part in better numbers (departure/arrival times, routing, scheduled stops; zero unscheduled), etc.
I'd weigh it next time. Start with an "empty" weight (driver plus full fuel) on a three axle certified scale [CAT Scale], and then as loaded for the trip. Adjust tire pressures to load.
Also, altitude, temps, humidity, barometric, etc.
It's all about prediction, IMO.
P.S. As a big truck driver: I want to be able to see you in my rearview, preferably from the drivers side. That means fall back far enough to be able to see that mirror yourself.
