Old 05-12-2008, 09:15 AM   #286 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by MPaulHolmes View Post
So, the only difficulty with centering is with the adapter plate, right? Lee Hart suggested to me that I use 2 separate plates, one for the bell housing, and one connected to the motor. Make two rough holes (you can be sloppy) in both of them. Mount the motor to the transmission (so the coupler should be done before this) and wiggle the motor around until there is the least amount of vibration. That is the center. Then "lock it into place" by some means, drill holes, and bolt the 2 together.
Have you seen the very recently added videos by the guy making his own coupler and adapter plate on youtube? He's going the WAY home-made approach.
Lee's advice is, as usual, elegant & workable.
Do you have a link for that YouTube video?
