Originally Posted by khafra
I, for one, like the cheap, reliable, automated 80% solution that errs on the side of safety. After watching my temps for a while in the Florida summer I don't know if I can afford to block my grill even partially at highway speeds; but I'd still like to see the build process and performance, when you get that youtube video up.
If your cooling system can't keep up un-modified, you may need to take a closer look at your cooling system. If your coolant is full and properly balanced and your thermostat is working, the radiator is most likely coated with minerals inside. It is a little know fact that only distilled water should go in a radiator to prevent efficiency killing mineral deposits..
