Old 07-22-2011, 07:16 PM   #5 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
emulation
Originally Posted by PaleMelanesian View Post
I aim for a constant 80% LOD through the whole pulse. That means I have to be adding throttle slowly as speed and rpm increase. It's possible that other cars do better with other lod values. A friend with an '03 Elantra reports his best at 70 LOD. I usually quote 75 for general purposes. With (basically) the same car I think we can get more specific.
I haven't found the throttle to be terribly sticky. It's certainly less tricky than many new cars with drive-by-wire throttle. With those it's more of a "think about moving your foot" proposition.
Just wanted to say that I began emulating your target of 80% load, sustained through the pulse. I can't say for sure if it is better but I think you are correct. Also wanted to add that if you follow my entries in my trip log labeled "Local freeway routes" you will see me testing the "GLEN" technique in a loose ABA style--"GLEN" being pulse and glide with the engine on in neutral. I use that technique on the freeway, and I think I could get over 60mpg @ 60mph on FLAT freeway stretches using it. In this technique I have also adopted your 80% load target. Cheers, james
