Old 07-23-2011, 03:07 PM   #168 (permalink)
aerohead
Project Update,maybe photos later
'been recycling metal into the gap-fillers.
I was given the late Bob Parson's sail car by his wife and I'm chopping up the steel tube truss sections to create the space-frames for the upper Viking gap-filler panel,as well as the T-100 rear,upper,inter-spanning gap-filler panel.
The Viking upper panel is 'there' and in a tack-welded condition.I've run it through the full range of motion and it's going to operate just fine.
I am nearly complete with one of the side-panel super-structures.I came up with a double-wheel bogey and single roller combo which 'ride' the prismatic trailer face,forcing the outward swing articulation of these panels as the trailer comes off-center during a turn initiation,all forced by contact of the lazy-C pivot-frame face with the contact rollers on the rear face of the integrator.
What remains,is a final roller which supports the outward lower rear extremity of the frame when on-center,should the rig encounter 'jerk' from a killer pot-hole,etc..The roller will roll atop a heavy aluminum bellypan section which cantilevers forward off the lower prismatic face on each side.
All the rollers are from recycled inline skates.1-skate will do an entire side.$2.
During near-jack-knife turning maneuvers the operating velocities should be low enough,and on level enough ground to permit survival of the lazy-C pivot-frame which carries the 'flag' side-panels.The lazy-C frame's weakness will be in torsion.So the support rollers should really help.
The tack welds will make 'corrections' easier,should I get stupid and have to re-engineer my engineering.
The fiberglass welding blanket has allowed me to weld 'directly' on/over the trailer.It's a nice addition to the shack.
So far,so good! No major surprises.
I'll get more photos taken soon,and post the few that I have if Al can break free.
The 'trumpet-player' should be back from Europe soon so my 'working vacation' is nearing its end and will have to go to work soon."#%@(*&)+_@*&^%!!!!!"
ID:	9054   Click image for larger version
ID:	9055   Click image for larger version
ID:	9056   Click image for larger version
euromodder (07-23-2011)
