Side note to WA state residents:
RCW 46.37.400 states:
“(1) Every motor vehicle shall be equipped with a mirror mounted on the left side of the vehicle and so located to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of such vehicle. (2) Every motor vehicle shall be equipped with an additional mirror mounted either inside the vehicle approximately in the center or outside the vehicle on the right side and so located as to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of such vehicle.”
So as long as you have a mirror on the drivers side that can see behind you 200 ft, and a regular rear view mirror, you are legal. I'm planning on getting one of those wide angle rear views and putting a convex side view on the interior left and right side.
