Old 07-25-2011, 12:49 PM   #18 (permalink)
War_Wagon
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
Originally Posted by roflwaffle View Post
Check the internal IP pressure, you'll probably need to reset it (Timing advance depends on fuel viscosity, which is lower with ULSD). Replacing, or at least keeping an eye on the seals is also a good idea. ULSD doesn't have the aromatics that kept older seals swollen and mostly leak free. People also like to machine the pump for more advance so they can retard idle more to quiet the engine. And get some new nozzles for the injectors, if they get really bad they can start screwing up the precombustion chamber cups and so on.
Just did some reading on ULSD, it hadn't occured to me that it could cause problems with the pump etc. Thanks for the heads up!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
