Old 05-12-2008, 03:12 PM   #25 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by monroe74 View Post
I'm also very intrigued by the possibility that WOT is optimal, and better than 70-80%, despite what I've heard about the penalties of open loop.
I'll just chime in an say that I also have doubts that the "rule" against going into open loop during P&G applies to all cars.
I've never spent much time watching loop status on the ScanGauge, except when I was initially curious to see how much time it took to switch over after a cold start. (Answer: in the depths of winter, no more than about 30 seconds).
But a couple of weeks ago, I called up that gauge while I was doing my usual P&G routine, and to my surprise, when accelerating I was in open loop most of the time! The transition point was much shallower than I had assumed.
I haven't tried to compare the difference between P&G with open vs. closed loop, but I will say that for my car at least, it doesn't appear to be a massive penalty. Consider the 104 mpg fill-up I saw last summer was using mostly open loop pulses (based on what I saw recently, using similar technique).
It definitely bears looking into.
