so do i have this right?
its a 7.3L IDI N\A, with E4OD auto trans 25% O\D, and 3.55 gears
if it is, direct drive will put you right at the 1,800 rpm MAX torque at 45 mph
factory turbo IDIs are 1,400 rpms
and the first power strokes 1994 1/2 year model, are 2,000 rpms for MAX torque.
non turbo 7.3Ls and 6.9Ls had two HP ratings each.
166 and 185 depending on what country they where made in.
don't remember what the 6.9Ls rating is but its a little less.
using your truck for work, you may know this but if not, read up......
are two auto trans fords 89 and 94 do a very strange thing but they do it from the factory
if the hazards are on it makes the converter stay unlocked, at all times.
same as pushing the brake and fuel peddle at the same time and unlocking the converter. the hazards use the same wiring as the brake peddel and delock the converter.
we KFC COUNTRY FRIED a E4OD with the 12.5K dozer on the trailer do to this.....
also for some E4ODs some do it with out help.
when you lock it in 2nd gear with the shift lever and go WOT with out the hazards on...
you can lock the converter in 2nd gear.
about 300/400 rpm drop on a steep hill pull with a big load
a massive drop in trans temp
but if you take your foot off the fuel peddle, you must repeat the proses.
1 86 T\D trooper with rare GEN 3 rods
TRANS FIXED
NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
