Originally Posted by Heihetech
Dear Dunkler, thanks for the interest and Welcome to Try Free DCD-440
Engineering Sample!
It looks no problem for your 6 points under which to try DCD-440 for free.
DCD has been played and test on many vehicles for almost 10 vehicle-years,
no damage was found in any vehicle tested. There's no reason to make any
damage. But it does break manufacturer's warranty, so that you need to
make sure either your vehicle's warranty period is over, or your vehicle's
manufacturer, Honda, will not refuse to make the repair under warranty once
DCD-440 product is installed.
Please let me know further details of your vehicle so that we can move
forward. Also please let me know your test plan and the test meter/gauge.
Heihetech, Specs for my vehicle are as follows:
Code:
Vehicle: 2007 Honda Fit Sport
Engine: 1.5 Liter In-Line 4-Cylinder
Engine Block/Cylinder Head: Aluminum Alloy
Displacement: 1497 cc
HP @ RPM: 109 @ 5800
TQ @ RPM: 105 @ 4800
Redline: 6500 rpm
Bore & Stroke: 73 x 89.4
Compression Ratio: 10.4 : 1
Valve Train: 16-Valve SOHC VTEC
Multi-Point Fuel Inj: YES
Drive by Wire Throttle: YES
Front Wheel Drive: YES
Carb Emissions Rating: LEV-2
My testing procedure is as follows: I commute everyday to work the same road and same speeds and same distance. It is exactly a 91.1 mile round trip for me on mostly hwy's traveling 55-60mph. I will use an Ultra-Gauge to record the results.
