Old 07-28-2011, 09:42 PM   #5 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
bikin' Ed,
I do hope you'll update your gas log for the Miata. People on the board can be more helpful if given more information.
I suspect Daox is right. With a small frontal area and probably an engine that's geared "short" for higher rpms, you likely can gain a lot by cutting the engine often. Because the fuel needed just to make it turn is substantial, especially at the higher rpms. Looks like it's a standard tranny so coasting with engine off is a definite possibility.
Since it's a '96 it's probably OBDII? Do you have a fuel economy gauge or just using the odometer and fuel pump data.
Coast long and prosper.
