Old 07-30-2011, 11:08 AM   #363 (permalink)
Brose
ManofGod
Cougar Troubleshooting!
I appreciate the help with my programming issue but it seems that I have another problem after getting the chip programmed. When I power it up I get the SOC screen and then the volt/bamp screen. At this point I can't change screens or do anything. The green LED is flashing and I changed the refresh speed to see if that could have been the problem but no luck, I also changed from manual to auto. When I did this I still got one screen and then the other but it never moved from the second screen. The green led dosen't come on when in auto mode. When I power up the green led come on flashing and the SOC screen comes up and without me doing anything the volts/bamp screen comes up and that's all it will do when I change back to manual. Does this make any sense at all?
