Old 08-01-2011, 09:35 PM   #13 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.65 mpg (US)
Originally Posted by Kodak View Post
Even from 2nd to 3rd? I assume we're geared the same. When I up-shift from 2 to 3, rpms drop 1k, so a 2500rpm shift puts 3rd at 1500 rpm, which I consider to be the lowest usable end. 4 and 5 are fine at 2500 or even a hair lower depending on the situation. Lately, I've been taking 2nd gear out closer to 3k, except for city driving.
Especially from 2nd to 3rd. If I'm stuck behind GrannyGoSlow, I'll upshift at 1500 RPM. If I'm pulling out into highway traffic, I may shift at 3000 or more. On a short on ramp, I'm willing to redline it in 2nd. My truck has the 3.73 rear axle ratio and 2% oversize tires, so turns slightly over 1800 RPM at 55 MPH in 5th.
On a perfectly level road, and if I'm not in a hurry, I will be in 5th at 20 MPH. It will accelerate from that speed at 8 or 9 lbs MAP. I don't do that very often, only when traffic prevents more efficient driving technique.
