No, I meant why didn't you research your questions? You were in research right? Took me mere minutes to do it and post up a link...
Re: snowblower carb leaking: if it's a float bowl carb like 99% of them are, it would be an issue with the needle valve and/or float or possibly the bowl gasket. Pretty easy to pop the bowl off and see.
