Old 08-08-2011, 12:56 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Go to page 31 in the manual and calibrate distance. Then when you fill up, go to page 30 to calibrate fuel usage. I calibrated mileage yesterday and played with the calibrations a little too much, resetting trip distance and whatnot, so I'm going to have to wait until the end of my next tank to calibrate the fuel.
I have to try this again too. I gave up after the first few tanks and assumed the readings would just have to be a little off, and rely on the odo/pump as the last word on mpg. But you make me want to return to it. I noticed that the milage is sometimes off by 10-15 miles at the end of a tank, other times it is amost spot-on. And the fuel usage is off by as much as nearly half a gallon sometimes, and other times near spot-on. I always go to the same pump, and I always pump a full 9-10 gallons in order to minimize pump variation. But still, the discrepancies with the UG change. Why?
