I understand how + why headers and fat pipes would help on a car that runs at or near WOT and between say, 4000-6000 rpm (assuming red line somewhere between 6-7K).
But if you're going for max mpg you likely run at half that rpm range or less, and nowhere near WOT. So where's the benefit of the huge capacity exhaust system? I've always read/heard that you do need SOME back pressure. Running at low throttle and low rpm's I'd think there's precious little back pressure even with a stock exhaust.
Coast long and prosper.
