Bubbling in an overflow tank has several causes: faulty radiator cap, stuck closed thermostat, faulty water pump, air pockets in the system (turn your heater on when bleeding it), blown head gasket.
I don't think that your P0118 would have anything to do with this, since it is an electrical circuit fault, and air bubbling in your overflow is a mechanical cooling system problem. The PCM uses the ECT sensor to determine fuel trims, closed loop, etc. If there is a problem with the ECT sensor, it may be staying in open loop, and you will notice a drop in fuel economy.
I fixed a car today that had a stuck closed thermostat, incidentally. Boiled a bunch of coolant out within minutes!
1992 Civic VX
