Old 08-10-2011, 01:53 PM   #47 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Vekke View Post
Today notised that if you like to push and glide with this 3L you only need to push the gas pedal. If you want to have maximum use of engine brake you just need to tap once to the brakes and ECU calculates which gear gives least braking while still on 0 fuel consumtion. Usually the change point is about 1000 rpm.
Now there is something I've never seen in a car! Did you find out by yourself, or is it mentioned in the manual?
