Originally Posted by Old Tele man
FWIW, our 2011 Cruze came from the dealership with green valve-stem caps bearing the letters "N2" on them...the dealership never mentioned whether they actually had put N2 gas into the tires or not.
...regardless, I just use regular "air" (78% N2, 21% O2) from the gas-station.
tell me your kidding????????
So, just following your thought pattern.........do you ramdomly put in desiel when the filler cap says gasoline????????
Why do you think the dealer needed to tell you?
it had N2 caps on it???????
good news though, now you can claim that N2 doesn't work!!!
