Old 08-11-2011, 08:26 PM   #8 (permalink)
Floordford
Muscle Car Modder
Floordford's Avatar
QuikSilver - '00 Ford Mustang GT
90 day: 24.7 mpg (US)
Originally Posted by moorecomp View Post
I agree that the fuel pump is not the way to go. Here is how I did mine. Not a Mustang, but a Ford.
http://ecomodder.com/forum/showthrea...tch-15943.html
On your engine, the common feed wire to the injectors is red also.
Had to do some digging but I found that my injectors also run off of a central red wire. But they also power other things after the injectors off that same wire. I may try a crude toggle switch to see if it throws a CEL. If it does its back to the drawing board. If im good then ill need to find a normally closed momentary push switch that can take that current all the time.
2000 Mustang GT
273hp/ 309ft.lbs.
Cd 0.36 Im working on it
