Originally Posted by Arragonis
Thats the best type of swap of all, nuts and bolts.
Plus a good bit of electronics, but that stuff doesn't scare me.
Originally Posted by slowmover
Did you happen to weigh the Cruiser prior to any changes? Am wondering about overall weight and changes to FF - RR axle weights once work completed.
Before - Heavy
After - Still Heavy
Cruisers are tanks...6000lbs+ easy. Weight is the last thing on my mind. The truck is going from a big iron straight 6 with an AL head to a big iron 4-cylinder with an iron head, turbo, injection pump, and associated plumbing. It's not on a diet, and never will be. I'll likely be adding armor, a lift, and bigger tires down the road too.
There is another fellow who just completed the exact same swap on his rig. With combined city and 70+MPH highway cruising he's returning FE numbers in the high 20's. If I get anywhere in the 20's, I'll be stoked.
