Thread: Tdi ac delete
Old 08-15-2011, 01:56 PM   #2 (permalink)
Josh8loop
Definately a Modder!
You'll need to install an idler pulley there to keep the belt tracking the way it should. You will also of course need to find a corrected length serp belt with the proper number of grooves in it. Why not leave the A/C compressor installed? You are always going to need a bearing there, so whether it's the one already on the compressor, or on the idler pulley it's still going to drag things down a bit.........Nevermind, I'm thinking ALH engine, you have a AGR-completely different!
Are you thinking of installing a Prius electric A/C compressor?
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
