Old 08-16-2011, 10:33 AM   #13 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by ZOMGVTEK View Post
It can get well below freezing here, and I run the recommended 5w20 year round. My last two UOA's were poor, but I hear the J30A1 tends to be a high wear engine. I somewhat recently started trying to get better MPG just because I can, and my engine uses no noticeable oil now. I used to burn .5-1qt per 3K, and then would change it when the level got to the bottom dot. I have 4K on it now, and it didn't budge from the top dot, which has never happened before. Same Penzoil Platinum 5w30 + Puralator PureOne w/ FilterMag RA300 as always. I'm probably going to be doing a oil change and send a sample to Blackstone this time around.
This discussion has made me revisit this again. Contrary to what O'Reilly Autoparts told me, I am reading that 0w pumps better at below-zero temps and behaves the same as its 30 or 20 weight counterparts with a 5w (source). Why isn't 0w always better, since better pumping at a cold start seems like it would always be better? BTW, the cited source claims Group 4 PAO based synthetic oils are the best for FE--as I think aporigine says in post 2 or 7 above.
