I also noticed this in the code, the subtraction went the wrong direction..
Code:
void Trip::update(Trip t){
seconds++; //we call update once a second
injPulses+=t.injPulses;
vssPulses+=t.vssPulses;
injHius+=t.injHius;
if (injHius>=1000000){ //rollover into the injHiSec counter
injHiSec++;
//injHius=1000000-injHius; // **this would result in a negative number
injHius-=1000000; // **correct
I'd considered using one of the inputs for the MAP signal, and also TPS. As for the fuel pressure changing.. I'm hoping to find more info on the factory FPRs.
