Thread: Nitrogen tires
Old 08-17-2011, 07:42 AM   #44 (permalink)
CapriRacer
Tire Geek
CapriRacer's Avatar
One aspect that hasn't been mentioned when folks talk up nitrogen inflation is that there's this pesky little thing called tha Law of Partial Pressure of Gases - also known as Dalton's Law. It states that if you have a mixture of gases, each gas behaves according to its percent by volume in the mixture.
Air is 21% oxygen, so oxygen acts like it's at 3.1 psi (14.7 X 0.21)
Where that plays out in tires is that even if a tire is completely filled with 100% nitrogen, oxygen is going to permeate back into the air chamber - and eventually the air chamber will stabilize at 3.1 psi oxygen. Put another way, if a tire is inflated to 31 psi with 100% nitrogen, eventually the air chamber will be 10% oxygen.
The Following 2 Users Say Thank You to CapriRacer For This Useful Post:
Mustang Dave (08-18-2011), t vago (08-18-2011)
