Old 08-18-2011, 08:58 AM   #17 (permalink)
markweatherill
Send a message via MSN to markweatherill
Originally Posted by busypaws View Post
With the back seat and passanger seat delete also deleted belts and passanger airbag. (Electrical tape over the Airbag light on the dash so I don't see that it is on all the time..
You can usually plug a resistor into the connector to fool the airbag ECU into thinking the removed airbag is still there.
On some cars, it's worth knowing that none of the remaining airbags will function if there's a fault detected ie airbag light on.
The Following User Says Thank You to markweatherill For This Useful Post:
California98Civic (08-18-2011)
