Originally Posted by PaulB2
I was looking at a couple of other threads on this subject, and it appears experienced mechanics think the clutch-disengaged coasting is OK. One thing I am wondering about is transmission bearings - are they pressurized by the oil pump or does the transmission simply run in an oil bath? If the latter then there can be no worries about them under coasting.
On a Suzuki GS500 the Parts of the transmission that are pressure lubricated are through a pressure reduction orfice > counter shaft bearing > drive shaft bearing, transmission gears, Primery driven gear bushing, clutch thrust bearing. The other transmission parts are splash lubricated.
