Old 08-19-2011, 07:04 PM   #55 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
Thanks for this info so I need to put the images to place where the adress will end to .jpg. On facebook that is not possible but on my webpages it is. So I will start to use that more then. I like the facebook because its three times easier to add photos than with my webpage software.
If I look at this page
then I can right-click on the image and select "copy image location" , which gives this :
Code:
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-ash4/296032_272488572765035_163711023642791_1284909_4084073_n.jpg
Put that URL between image tags
Code:
[IMG]URL[/IMG]
and it'll give this :
PS : the links you've given are secure httpS links.
It's better to use the normal links, starting with just http .
On the outside? WTF!.......goofy spy plane..........spies must alway be looking behind.
On the U-2 / TR-1 it's used to check for contrails.
The Following User Says Thank You to euromodder For This Useful Post:
Vekke (08-20-2011)
