Old 08-28-2011, 09:25 PM   #66 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Patrick View Post
No, they would still work. The idea is to get the center of pressure behind the center of gravity. If the CG is further back you may need larger fins, more fins, or the fins may need to be positioned further back to get the same effect. Or you can reposition some other items to move the CG forward.
And according to Craig Vetter and others who have made high MPG motorcycles with high efficiency airfoils, they have moved the mass as forward as possible and added a fin to the rear for stability.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
aerohead (04-14-2012)
