Old 08-31-2011, 10:30 PM   #91 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.6 mpg (US)
Originally Posted by Clev View Post
My '04 Saturn turns on the A/C silently (no light) whenever the dial is set to defrost--even if the recirc is not on. One of these days, I'm going to pull that panel and cut that wire...
My Canyon is the same. I tried to cut that wire. Not possible. The defrost selector is built onto a tiny circuit board, along with the A/C switch. The output of that board sends a signal to the body control module, which toggles the A/C compressor. I could cut that wire and replace the A/C switch with a toggle switch, but I'd rather not do that sort of cob job on an almost new truck. I just pull the A/C compressor fuse instead.
