Trust me on this...
I tried it on an I-4, it didn't work, and used more fuel.
On later engines, the Fuel-Injection system (and oxygen sensor feedback loop) requires a pre-determined ratio. If you override this, it might benefit, but...
You'll have hot and cold spots and pumping losses. An engine swap is easier...
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
