Old 09-03-2011, 05:48 PM   #16 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Originally Posted by Arragonis View Post
Before you dig into the SDi frugality, don't forget they have a fragile gearbox - shared only with the 1.6 Petrol (and we know how popular they are) and not the same as the TDi. Plus the gearing is lower so as well as being very very very very slow they are also noisier and thirstier than they need to be.
A quick Autotrader search with 10 miles and £1k max price brings up quite a few. How about a Vectra DTi (the good one with an intercooller) or how about the minicabbers old fave the 406 - there's a 1999 facelift estate HDi with 110K miles on it near me.
If you want a bit of go and some reasonable modern-ness how about a late-ish 1.4 HDi 206 ? Or even a 2.0 ?
2001 PEUGEOT 206 DIESEL 3 DOOR
£675, although the ad doesn't give mileage so I suspect its been to Mars and back
EDIT - I would also skip LPG, adds weight and you need to do about 18K miles to get your money back. Plus your iS will be worth more kept in original condition.
I’m gonna avoid the French Peugeot/Renault lot you’ve suggested, as I know too many folks that have had issues with HDi lumps.. and the 206 is a Hateful Hateful car!
If I go Diseasal, it’ll be German or Japanese..but as you say, probably avoiding the Sdi setup from VW
Depends what the LPG quotes are like
Originally Posted by euromodder View Post
Were there any good DTi's then ?
I've had a couple of Astra company cars.
The 1.7 DTi was a snail.
Didn't burn much, but didn't go either.
The 2.0 DTi was a two-stroke diesel.
Over the regular oil change interval, I added almost as much oil as was in it.
That was considered OK, as others burned even more oil.
In the beginning, we got 1L oil bottles to fill up. Later on, 5L bottles
Dunno if GM ever got that oil issue sorted.
Herein lies the reason that the only Vauxhall I’d look at would be an Omega 2.5td..and even then it’s not that good a lump(and I know it’s a BMW lump)..but its RWD
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
