Old 09-05-2011, 11:47 PM   #295 (permalink)
bungie4
Originally Posted by dcb View Post
cautionary tale on the motorcycles, the numerous tiny pulses from the abs sensor are not compatible w/a stock guino. You need something in the 3000-5000 pulses per mile range as is typical in car speed sensors.
I did a little more research into this (thanks for the heads up!). It seems my Honda has a true VSS mounted to the gearbox just behind the cylinder. In fact, it seems most honda's have this. So I'm hoping I can forgo tapping into a reducing the signal from the ABS.
Right now it's looking like the hardest part is going to be fabbing up a mounting box and mount. (I just jinxed myself didn't I).
I plan on doing up a full install report with photo's but the weather here is starting to turn so it might be a long winter project. I have access to some bit twiddlin' hardware guys who do remote operated mining equipment, and, I'm a programmer (going on 30 years now). I figure we should be able to git'r done.
-Steve
