Originally Posted by brandonppr
I gave it a try. At first I thought my DIC was not logging the miles because it would say 0mpg with engine off key on, but when I restarted it my avg mpg jumped up. I only drove down to the store a few miles from my house so I haven't had time to try it out, but I did increase my DIC avg MPG by 1 MPG in a short trip.
PLEASE CHECK TO make sure your auto trans can be operated with the car off. If it cannot you will eventually damage the transmission because fluid is not circulating while the car is off. One way some have suggested checking is by researching online or in the owners manual as to whether you car can be flat towed, which, they say, would mean it can run EOC too. But I would not know. The safest bet with an auto trans is always to keep the enine on and coast in neutral or in gear. Good luck!
