Originally Posted by Arragonis
One thing worth noting from this image
is the lack of silencer (muffler) on the exhaust. I was following it through and there is a single box which is mounted at the rear, with the input and output ends (if thats the correct phrase) on the same end.
i'd agree with Piwoslaw about the mounting of the muffler..
Also, take it the Cat is "upstream" of the lamda sensor at the top of the picture? If so, the cat must be tiny!
Can see several easy points to attach the bellypan too-and it looks nice and clean to work under there.. A liberal coat of Waxoyl wouldnt go a miss either.
Would you consider deleting the mufffler totally? Straight thru FTW!
