05-15-2008, 12:19 PM
#21 (permalink)
Another reason for using the p-brake regularly is that they tend to seize up when not used. Which means you could be facing (A) a stuck brake that won't release if you ever do apply it, or (B) a brake that won't engage should you really need it (hydraulic brake failure - ie. "emergency" brake).
