Originally Posted by Arragonis
You may find 2.6K at 70 will be too high for the 2.0 (is this your engine) to pull effectively, thats not too far (2.3K) than my previous TDI pulled in 6th - and that had 250+lb/ft @ 2200
the HP for my car vs the 626LS is pretty close, so I dont think I will have any issues. plus, there are some people already running that trans in their FS-DE engines
like I said, the only downside from the trans swap is slower acceleration, which for me isnt much of a downside at all, I have a MX6 LS for going fast.
@ Sven
I tried it both ways, and with the upper blocked off, regardless if I had the lower one blocked off, it would run hot. but not so hot as to keep me from using both upper and lower when temps drop some.
I coast a lot as it is, and can usually time my lights well enough where the lowest gear I need to be in is 2nd, but most of the time its 4th/5th. Im not real comfortable bumpstarting an FWD car as Ive read numerous times over the yrs how damaging it is. but I do EOC into my condo complex, usually from the hwy, only comes out to be about 300+' all said and done, but since I do it every time I come home, it adds up.
