Old 09-10-2011, 05:20 PM   #3 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by groar View Post
The bad news :
  • the engine makes a strange noise when it's started with the new switch turned off
  • it makes the same strange noise when the new switch is turned off while the engine is on
What kind of noise -- does it sound like it is harder to start (and any additional black smoke from the exhaust)? Is it like if you don't wait for the plugs to warm up and you start early?
Maybe the ECU is concerned about the turbo -- is there an increase in consumption with the switch on during normal operation (or the ability to monitor boost in this situation)?
Just brainstorming -- but great find with the plugs and working the problem!
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
