Old 09-11-2011, 02:22 PM   #89 (permalink)
Arragonis
The PRC.
Originally Posted by 320touring View Post
i'd agree with Piwoslaw about the mounting of the muffler..
Also, take it the Cat is "upstream" of the lamda sensor at the top of the picture? If so, the cat must be tiny!
Can see several easy points to attach the bellypan too-and it looks nice and clean to work under there.. A liberal coat of Waxoyl wouldnt go a miss either.
Would you consider deleting the mufffler totally? Straight thru FTW!
I have enquired on various forums about "bugs" and they seem to think the underneath is protected enough. I'm not so sure and I have a pot of Waxoyl available. The problem is if I put it on then there may be implications for the warranty - such as it is.
And yep - the underside needs to be sealed I think. There is nothing missing, I have dived under new ones at the stealers and they are all like that
Added a new tank for both cars over the weekend - both are lower than before which probably reflects life this week. Both Mrs A and I have been working all this weekend setting up stuff that other people at work should have been setting up for a demo / presentation next week. We only told them last Monday only to find they had done nothing by Friday and are clueless - we will moan a lot at work about that one.
Target for this tank for George is 65, a little back from 70 but targets are made to be moved, no ?
