Originally Posted by flores
Hi.. can you post the exact error message? maybe I can help..
Hello Flores, The details of the fault code are quite lengthy but I'll give it a try.
I load the RTD explorer and when i try and start the program I get:" Cannot start application check network connection or contact your system administrator or network service provider".
When I look at the "details tab" in the text box I get, and this is where its going to get lengthy you read that there looks to be a remote name that could not be resolved and therefore the program does not deploy. I do not write code so all i see is a lot of code.!
PLATFORM VERSION INFO
Windows : 6.1.7600.0 (Win32NT)
Common Language Runtime : 4.0.30319.237
System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100)
clr.dll : 4.0.30319.237 (RTMGDR.030319-2300)
dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll : 4.0.31106.0 (Main.031106-0000)
SOURCES
Deployment url : file:///C:/Users/MikeS/AppData/Local/Temp/Temp5_publish.zip/publish/RTDExplorer.application
Deployment Provider url :
http://bobert5064-win7/RTDExplorer/R...er.application
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\MikeS\AppData\Local\Temp\Temp5_publish.zi p\publish\RTDExplorer.application resulted in exception. Following failure messages were detected:
+ Downloading
http://bobert5064-win7/RTDExplorer/R...er.application did not succeed.
+ The remote name could not be resolved: 'bobert5064-win7'
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [9/11/2011 3:25:12 PM] : Activation of C:\Users\MikeS\AppData\Local\Temp\Temp5_publish.zi p\publish\RTDExplorer.application has started.
ERROR DETAILS
Following errors were detected during this operation.
* [9/11/2011 3:25:15 PM] System.Deployment.Application.DeploymentDownloadEx ception (Unknown subtype)
- Downloading
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.SystemNetDownloader. DownloadSingleFile(DownloadQueueItem next)
at System.Deployment.Application.SystemNetDownloader. DownloadAllFiles()
at System.Deployment.Application.FileDownloader.Downl oad(SubscriptionState subState)
at System.Deployment.Application.DownloadManager.Down loadManifestAsRawFile(Uri& sourceUri, String targetPath, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.Down loadDeploymentManifestDirect(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.Foll owDeploymentProviderUri(SubscriptionStore subStore, AssemblyManifest& deployment, Uri& sourceUri, TempFile& tempFile, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.DownloadManager.Down loadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator .PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator .ActivateDeploymentWorker(Object state)
--- Inner Exception ---
System.Net.WebException
- The remote name could not be resolved: 'bobert5064-win7'
- Source: System
- Stack trace:
at System.Net.HttpWebRequest.GetResponse()
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
