Old 09-13-2011, 05:00 AM   #4 (permalink)
oil pan 4
In the old small block chevy the aluminum version was a full 100lb lighter than the cast iron ones.
The difference between cast iron and aluminum blocks in the newer engines is about 70-80lb.
With 4 cylinder engines I would expect the weight difference between cast iron and aluminum to be about half that.
