Old 09-14-2011, 11:12 AM   #17 (permalink)
JPD
Originally Posted by jsatter View Post
Great job. The Aveo rates at around 28 mpg, so 40 is a 43% gain.
Losing all the weight, no doubt, reduced the fuel used to get up to speed.
A little bit of over inflation of the tires, if you're comfortable with that will give you a boost.
A grill block and smooth wheel covers are great projects that will get you some gains as well.
Keep it up!
Hi, I've got an Aveo, I've seen the thread about the grille block, do you have any information about smooth wheel covers and how to make them for an Aveo?
