Originally Posted by cfg83
What the heck is the "paddle thingy" in the middle? I couldn't figure it out from the website. Is it a sensor for turning the misters on and off?
CarloSW2
Yup, that's what it does. The photo shows it in "On" mode -- where the fan blows upward and engages the mist. As it shuts down, the paddle lays flat and closes the valves.
I need a Y-splitter if I use the hose -- easy fix. Maybe the splitter will have a higher quality thread and gasket seal surface for the filter.
We get lime scale, etc -- which probably shouldn't be going into the A/C unit, as I think about. The filter probably should go on there somehow...
RH77
