Old 09-16-2011, 10:58 PM   #16 (permalink)
KnightmareCS
Post 6
www DOT gassavers DOT org/showthread.php?t=12156
www DOT autospeed DOT co DOT nz/cms/A_1716/article.html?popularArticle
closed loop monitor
I built this and it works great. You can change the comparator to light for closed loop or open loop. I have two green LEDs on the dash one lights for injectors off and they both light for lean burn.
________________
The closed loop monitor uses a comparator curcuit. You set a voltage and you can wire it to light above or below that voltage. Injectors off is a certain voltage(I forget what it was) so I made two curcuits one is set to monitor lean burn the other monitors the injectors.
________________
Exactly what I said to do.
1995 Honda Civic VX Hatchback - Bone stock. - 175 tires.
