Old 04-28-2011, 12:31 PM   #11 (permalink)
Crx-Vx - '90 Honda CRX VX
90 day: 45.43 mpg (US)
A8 on my ecu is not leanburn or I haven't gotten into leanburn yet... But it only lights up when I start the car...
Old 04-28-2011, 11:02 PM   #12 (permalink)
Originally Posted by steffen707 View Post
So i clicked on this link and it takes me to a $200 O2 sensor. Where is this $77 one you speak of?
Anybody found this $77 o2 sensor? I'm only seeing the $200 one.....
Old 07-16-2011, 08:34 PM   #13 (permalink)
o2 sensor update
I am also interested in a cheaper alternative to the $200 sensor. I don't have a check engine light or a code but I suspect that my o2 sensor is lazy. I keep getting 29 - 35 mpg depending on city/hwy mixture. I wish there was a place I could buy this sensor for less.
Please let me know if anyone has a solution to this...
Thanks
Old 07-18-2011, 08:10 PM   #14 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Ahhh, the phantom Lean Burn LED.
If anyone has the recipe for this I'm interested. Can you get the input signal from the Oxy sensor itself?? I'm actually more comfortable tapping into a wire under the hood than I am hacking into the connectors at the computer .
Coast long and prosper.
Old 09-13-2011, 12:20 AM   #15 (permalink)
Question
I don't see why this so hard. You already can tell if you're in lean burn by monitoring whatever voltage to see if it goes positive. Why can't you use the same pins and run a wire from them to a circuit which relays a LED when the voltage is positive or whatever range? You can use a pot to fine tune the lean burn range light up. I'll ask my friend what he would suggest, but it seems like a straightforward doing.
1995 Honda Civic VX Hatchback - Bone stock. - 175 tires.
Old 09-16-2011, 09:58 PM   #16 (permalink)
Post 6
www DOT gassavers DOT org/showthread.php?t=12156
www DOT autospeed DOT co DOT nz/cms/A_1716/article.html?popularArticle
closed loop monitor
I built this and it works great. You can change the comparator to light for closed loop or open loop. I have two green LEDs on the dash one lights for injectors off and they both light for lean burn.
________________
The closed loop monitor uses a comparator curcuit. You set a voltage and you can wire it to light above or below that voltage. Injectors off is a certain voltage(I forget what it was) so I made two curcuits one is set to monitor lean burn the other monitors the injectors.
________________
Exactly what I said to do.
Old 01-04-2012, 02:50 PM   #17 (permalink)
Any know were to get the o2 sensor for cheaper that 200?
Old 12-23-2012, 03:07 PM   #18 (permalink)
what do I see in voltage if BAD O2 sensor?
I suspect my O2 sensor... slight hesitation, apparently no lean-burn (by looking at the MPGuino there is no jump). When I unplug the O2 sensor, hesitation goes away.
So, I'm about to solder in some wires so I can easily check the voltage and monitor the O2 sensor/lean-burn. From this thread I can see what I *should* be seeing, but what would you expect to see if the sensor is bad? Is there any clear indication?
Also, I've been wondering, is lean-burn a binary situation? on/off? or is it an incremental adjustment in amount of fuel made by the ecu in response to the o2 sensor signal? That pertains to whether an idiot light would be meaningful.
I'm probably going to wire in one of these: www{dot}adafruit{dot}com/products/705
and add on a vtec led somewhere.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
lean burn rules~! coolwHip Introductions 42 10-01-2011 05:42 AM
Max lean burn horsepower with VX engine. basjoos EcoModding Central 13 02-08-2010 11:04 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Civic VX lean burn ivicR DIY / How-to 43 10-22-2009 01:40 AM
