Old 09-17-2011, 03:53 PM   #1 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Battery mod not working out?
I have installed an onboard voltage meter so I can monitor it live while I drive. I have a new lightweight deep cycle battery that seems to work fine. I charge it at night and in between runs with a plug in on board 1.5amp maintainer. My goal is to install an alt disable switch for short runs, such as my 22 mile round trip commute. Some observations and questions:
While in EOC during daylight the charge will sit at 12.5 volts and when I bump start it instantly jumps to 14.3 or 14.4. Back to EOC it drops to about 13.0 or 13.1 and then starts to descend to 12.5, getting there inside a minute, maybe less. Then it will sit stable at 12.5 volts.
Question is: that is quite normal, no? But doesn't it indicate that my alternator is coming on immediately upon bump starting, every time? If so, doesn't that mean that I won't really get the benefit of the deep cycle battery until I can disable the alt?
