Old 05-15-2008, 10:54 PM   #37 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Originally Posted by Arminius View Post
Remember that vinegar is a natural descaler (5% acidic), and it's cheap.
Works for the coffee maker -- why not the A/C
At any rate, I'll monitor any build-up and take photos as needed.
I have a question for anyone familiar with heating and air...
The A/C engages the blower fan at a slower speed than the heat. I found this out through the thermostat, which has an "Auto" setting for heat or air. I turned the blower into the "On" position and noted that the speed slowed for the A/C compressor. After 5-minutes of compressor shutdown, the blower speed went back up to full revs.
The system constantly runs in the hot Summer months. Would it be better to resolve the speed issue and run it on full -- or is it like a car, where cooler air can be felt without the use of excess fan speed???
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
