Old 09-18-2011, 09:08 AM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Your typical 40lb lead acid battery holds up to 2 kwh from 0 to a full charge and about 1kwh of useable power between 12.8v to 10.8v volts.
Running it yesterday afternoon without the alt, the car ran more smoothly. Batt only got down to about 12.1 volts. I'll experiment with running it lower today, closer to 11.0 maybe if the car shows no sign of operating difficulty. Sound reasonable?
I had a 1.5 amp charger for a long time, seemed to work ok for my car, but was useless for propery charging the large battery in my truck.
My new battery is actually smaller than stock. I considered a smaller and a larger battery for a long time. For the sake of my weight reduction goals, I took the risk. I know it might not last or might not even workout, but I wanted to experiment. Both the maintainer and the battery mount nicely on the stock battery tray.
From what I have found solar panels that put out any less than 17 or 18 OCV are useless for charging 12 volt batteries, they look cool but don't really do anything.
If I understand correctly, I should be fine. The panels I am considering have an optimum voltage of 18 volts. Did I understand correctly?
