Old 09-18-2011, 11:05 AM   #1 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
OBDII Port Question
Hey Guys and Gals,
I have a question for some of the more technically inclined members.
As I understand a Mini Cooper / Mini Cooper S does not work well with the Ultra Gauge. This stems from the Cooper Programming remaining active up to 10 minutes after the ignition has be shut off.
A simple solution would be to plug and unplug the gauge, this is a an absolute pain in the a patoot!
I was thinking, could you just use a OBDII port-2-port (male-2-female) connector and add in a push-button power switch for pin number 16. I know you can purchase cable ends, but there is quite a bit of wiring and muttering to be done to create such a device. So I was wondering if anyone knows of a extension cable or of a OBDII port already pre-assembled with a power switch?
If you're confused for what I am talking about, I did find a right angle cable end with a power button built in, but I would have to splice all the UG wires...which then runs the possibility of ruining the UG completely.
http://www.fes-auto.com/upload/doc/5...connectors.pdf
Any suggestions appreciated!
